We have a Portal 10.7.1 and GIS Server 10.7.1 as the hosting server. We are using the most current Collector on iOS.
I've created a web map and added a hosted layer created from a template in Portal. The layer is sync enabled and the web map is offline enabled.
In Collector on iOS, the On-Demand workflow is able to download the Map Area, however the Pre-Planned Map Areas fail every time saying that the replica with guid cannot be found on the server.
Has anyone seen this behavior and been able to determine the cause? We are thinking it is auth related, but since it works with one workflow and not the other I am hoping a more technical esri person could chime in. Is this a bug, or is our system's auth broken somehow?
thanks!!
