Hi all,I have a Javascript web map in which the user manually selects layers by dragging a box, using the Identify Task. I have it working where if features from one layer are selected, the results are displayed in a datagrid. The problem I am having is if two layers overlap and the user selects them both, I can't figure out how to display results for both. I have tried multiple things and am yet to come up with a solution. I am open to either having both datagrids displayed at the bottom, or giving the user a choice through a pop-up window of which grid results to show. The last chunk of the else/if statement where I try to put both the layers together does not seem to be working....any ideas????Thanks so much!!!
dojo.connect(map, 'onLoad', function(theMap) {
navToolbar.deactivate();
identifyTask = new esri.tasks.IdentifyTask("http://slcarcgisdev1/SLCOGIS/rest/services/public/Surveyor/MapServer");
identifyParams = new esri.tasks.IdentifyParameters();
identifyParams.tolerance = 3;
identifyParams.returnGeometry = true;
identifyParams.layerIds = [0,2];
identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
identifyParams.width = map.width;
identifyParams.height = map.height;
//initialize the toolbar
toolBar = new esri.toolbars.Draw(map);
dojo.connect(toolBar, "onDrawEnd",onDrawEnd);
//resize the map when the browser resizes
dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
function onDrawEnd(extent){
executeIdentifyTask(extent);
function executeIdentifyTask(geom) {
//clear the graphics layer
map.graphics.clear();
var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DOT, new dojo.Color([151, 249,0,.80]), 3), new dojo.Color([151, 249, 0, 0.45]));
var markerSymbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 20, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0, 0, 0]), 1), new dojo.Color([25,50,225,0.3]));
identifyParams.geometry = geom;
identifyParams.mapExtent = map.extent;
identifyTask.execute(identifyParams,function(response){
var controlItems = [];
var surveyItems = [];
dojo.forEach(response,function(result){
var feature = result.feature;
//add selected feature to graphics layer
feature.setSymbol(polygonSymbol);
feature.setSymbol(markerSymbol);
map.graphics.add(feature);
if(result.layerName === 'Control Points'){
showPointNameGrid();
controlItems.push(feature.attributes);
searchType = "selControl";
var controlStore = new dojo.data.ItemFileReadStore({data:{identifier:'POINT_NAME',items:controlItems}});
var grid = dijit.byId('grid4');
grid.setStore(controlStore);
}else if(result.layerName === 'surveys'){
showSurveysNameGrid();
surveyItems.push(feature.attributes);
searchType="selSurveys";
var surveysStore = new dojo.data.ItemFileReadStore({data:{identifier:'DOCUMENT_N',items:surveyItems}});
var grid = dijit.byId('grid5');
grid.setStore(surveysStore);
}else if((result.layerName === 'surveys') && (result.layerName === 'Control Points')){
var surveysStore = new dojo.data.ItemFileReadStore({data:{identifier:'DOCUMENT',items:surveyItems}});
