I released a map in August. At that time, I was using MapImageLayer to pull in my trails layer. All was working as expected. I noticed yesterday that the trails are no longer pulling in and displaying on my map. I've republished the service and have checked that it is working. My code hasn't changed, so I assume there has been a change elsewhere that is affecting the layer. I haven't been able to narrow down the issue yet. Any ideas?
Here's the code:
<SPAN class="comment token">//Add SP trails feature layer </SPAN>
<SPAN class="keyword token">var</SPAN> spTrailsLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapImageLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"https://conservationgis.alabama.gov/adcnrweb/rest/services/DCNRTrails/MapServer"</SPAN><SPAN class="punctuation token">,</SPAN>
sublayers<SPAN class="punctuation token">:</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>id<SPAN class="punctuation token">:</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
popupTemplate<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"{TrailName}"</SPAN><SPAN class="punctuation token">,</SPAN>
content<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Trail Type: {TrailType}<br><br>Located On: {Tract}<br><br>Length (mi.): {Mileage}"</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
definitionExpression<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"SPorFW = 'SP'"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"State Park Trails"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
spTrailsLayer<SPAN class="punctuation token">.</SPAN>minScale <SPAN class="operator token">=</SPAN> <SPAN class="number token">250000</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// watch handler: the callback fires each time the scale of the view changes</SPAN>
<SPAN class="keyword token">var</SPAN> handle <SPAN class="operator token">=</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">watch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'scale'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>newScale<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Scale: "</SPAN><SPAN class="punctuation token">,</SPAN> newScale<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>newScale <SPAN class="operator token">></SPAN> <SPAN class="number token">250000</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
spTrailsLayer<SPAN class="punctuation token">.</SPAN>listMode <SPAN class="operator token">=</SPAN> <SPAN class="string token">'hide'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN>
spTrailsLayer<SPAN class="punctuation token">.</SPAN>listMode <SPAN class="operator token">=</SPAN> <SPAN class="string token">'show'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
