I have a form that allows users to update attribute information for selected features...but I'm recieving the error: "Exception from HRESULT: 0x80041051" when it tries to update the data. I'm using VB.net, Visual Studio Express 2008 and ArcGIS 10.Any suggestions on where I went wrong with updating the data?
System.Runtime.InteropServices.COMException was caught
ErrorCode=-2147217327
Message="Exception from HRESULT: 0x80041051"
Source="ESRI.ArcGIS.Geodatabase"
StackTrace:
at ESRI.ArcGIS.Geodatabase.IFeatureCursor.UpdateFeature(IFeature Object)
at ImprovementProjectsLines.ImprovementLines.cmdUpdate_Click(Object sender, EventArgs e)
InnerException:
CODE: Private Sub cmdUpdate_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmdUpdate.Click
Try
Dim pMxDoc As IMxDocument
pMxDoc = My.ArcMap.Document
Dim pMap As IMap
pMap = pMxDoc.FocusMap
Dim pFLayer As IFeatureSelection
'Get a reference to the editor.
Dim editor As IEditor
editor = My.ArcMap.Application.FindExtensionByName("esriEditor.Editor")
'Get Crossings FeatureLayer
Dim pFeatLyr As IFeatureLayer
pFeatLyr = GetLayerByTOC("TransportationImprovementProjects_Lines")
'Get Dataset from FeatureLayer
Dim pEditDataset As IDataset
pEditDataset = pFeatLyr
'If not editing, start editing dataset's Workspace
If editor.EditState <> esriEditState.esriStateEditing Then
editor.StartEditing(pEditDataset.Workspace)
End If
'Get SelectionSet
Dim pSelSet As ISelectionSet
pSelSet = GetSelection(pFeatLyr)
'Get FeatureCursor from SelectionSet
Dim pFCursor As IFeatureCursor
pSelSet.Search(Nothing, True, pFCursor)
'Initialize first (only) feature
Dim pFeat As IFeature
pFeat = pFCursor.NextFeature
'Update attributes with user input
'Fill in Attributes of selected feature in User Form
Do Until pFeat Is Nothing
pFeat.Value(pFeat.Fields.FindField("YEAR")) = txtPrjYear.Text
pFeat.Value(pFeat.Fields.FindField("PROJECTYPE")) = txtPrjType.Text
pFeat.Value(pFeat.Fields.FindField("LOCATION")) = txtLocation.Text
pFeat.Value(pFeat.Fields.FindField("AGENCY")) = txtAgency.Text
pFeat.Value(pFeat.Fields.FindField("DESCRIPTION")) = txtDescrip.Text
pFeat.Value(pFeat.Fields.FindField("COST")) = txtCost.Text
pFeat.Value(pFeat.Fields.FindField("DATEEDITED")) = txtDate.Text
pFeat.Value(pFeat.Fields.FindField("USEREDITED")) = txtUser.Text
pFCursor.UpdateFeature(pFeat)
'pFeat = pFCursor.NextFeature
Loop
'Stop editing and save edits
editor.StopEditing(True)
'Close form
Me.Close()
Catch ex As Exception
Windows.Forms.MessageBox.Show(ex.ToString, "error")
End Try
End Sub
Public Function GetSelection(ByVal pFeatLyr As IFeatureLayer) As ISelectionSet
'Gets selection of feature layer and returns selection set
'Initialize the required variables
pMxDoc = My.ArcMap.Application.Document
Dim pFeatSel As IFeatureSelection
pFeatSel = pFeatLyr
GetSelection = pFeatSel.SelectionSet
End Function
Public Function GetLayerByTOC(ByVal lyrName As String) As IFeatureLayer
'This function finds a feature layer based on its TOC Name
'Initalize global variables
Dim pMap As IMap
Dim lyrCntr As Integer
For lyrCntr = 0 To pMap.LayerCount - 1
'Ensure that the layer is valid
If pMap.Layer(lyrCntr).Valid = True Then
'Ensure that the layer is a feature layer
If TypeOf pMap.Layer(lyrCntr) Is IFeatureLayer Then
pFeatLyr = pMap.Layer(lyrCntr)
If UCase(pMap.Layer(lyrCntr).Name) = UCase(lyrName) Then
GetLayerByTOC = pFeatLyr
Exit Function
End If
End If
End If
Next lyrCntr
Return Nothing
'Layer not found. Show a message
MsgBox("Layer " & lyrName & " not found !", vbCritical, "Error")
End Function
