Hello System Windows Vista ArcGIS 9.3Now I have a shape file. Its attribute table consisted of fields of GridCell ID (GID) and species ID starting with D. (Dxxxx (such D8729, D6745, D2765))The rows are GridCell ID (0-4800).Each cell in the attribute table has either 1 and 0.I would like to create a new field called All.In the field All (Long 9, 9), the cell would should be assigned 1 when the cell of Dxxxx is 1. Otherwise, the cell would be 0.The code can run the requirement above for one field. Please kindly advise how to add the loop process for the multiple fields of DxxxxThank you in advance.the code##Script Name: calculate sum ##Description: calculate sum of merged range sizes of a taxonomy of migratory birds ##Created By: Elaine Kuo ##Date: 07/18/2015 #Import standard library modules import arcgisscripting import os #Create the Geoprocessor object gp = arcgisscripting.create(9.3) #Set the workspace. gp.Workspace= "H:/temp_D/test_1" #Set the workspace. List all of the feature classes in the dataset outWorkspace= "H:/temp_D/test" #Get a list of the featureclasses in the input folder fcs = gp.ListFeatureClasses() # Loop through every item in the list that was just generated for fc in fcs: # Break out the name, no path or extension, using the describe object. desc = gp.describe(fc) featureName = desc.name # Add a field to this shapefile, of type LONG gp.AddField (fc, "All", "Long", 10,10) # Make temporary featureclasses gp.MakeFeatureLayer(fc,"lyr") # Get a list of the fields in the featureclass fields = gp.ListFields("lyr", "D*", "Long") # Loop through every item in the list that was just generated for field in fields: gp.toolbox = "Data Management" # Select records to be copied (C*, i.e. C7658) query = "\"%s\" = 1" % field.Name gp.SelectLayerByAttribute("lyr", "ADD_TO_SELECTION", query) # copy values in existing fields to the new field gp.CalculateField("lyr", "All", "1", "PYTHON_9.3") #Validate the new feature class name for the output workspace. #OutFeatureClass = outWorkspace + os.sep + gp.ValidateTableName(fc,outWorkspace) # clear memory of layers gp.Delete("lyr") gp.AddMessage(gp.GetMessages()) print gp.GetMessages()
