We are using Enterprise 11.5
I need all the tables added to the Table widget in Experience Builder to show the fields in the same order as the layer.
For layers explicitly added to the widget in its properties, I can set this by clicking 'Select All' in the fields tool for each layer in the web map, which then sets the table and popup to the layer order.
But for layers that are not explicitly added to the Table widget, the tables added using the 'Add To Table' tool from the layer list options in experience Builder default to alphabetical order, even though the popups and table are set the same way as the others in the web map (using the layer's order).
How can I change this? The default to alphabetical order is not useful for us.
