we have the following Environment:
ArcGIS Enterprise 11.5, single machine: IIS + Web Adaptor (/server and /portal), ArcGIS Server and Portal for ArcGIS on the same host
About 0.1–0.2 % of requests through the Web Adaptor take almost exactly 15 s (IIS time-taken between 15,000 and 16,000 ms). Mostly affected are /portal/sharing/rest/oauth2/token requests from service clients and health checks. The responses themselves are fine (HTTP 200).
What we found by correlating IIS, FREB and ArcGIS Server logs
- IIS receives the request immediately. In Failed Request Tracing, all IIS modules finish within the same millisecond, then the request sits inside AspNetCoreModuleV2.
- ArcGIS Server logs the request only ~15 s after IIS received it, and then processes it in 50–500 ms (service instance wait time 0 ms).
- During those 15 s, ArcGIS Server is healthy: its direct health checks keep answering. Almost no other requests arrive via the Web Adaptor in that window.
- The stall depends strongly on idle time on that path (Web Adaptor → Server / Portal):
Idle time before request | Share of requests that stall ~15 s |
< 50 s | ~0 % |
60–70 s | ~6–7 % |
90–120 s | 12–85 % |
This looks like the Web Adaptor reusing a pooled backend connection that has become unusable after ~60 s idle. It only notices after ~15 s, then retries on a new connection.
Questions
- Is this a known issue with the ASP.NET Core based Web Adaptor (IIS)? Is there a patch or BUG number?
- Can the idle / keep-alive timeout or the ~15 s timeout of the Web Adaptor's backend connection pool be configured, for example in web.config or webadaptor.config?
- What keep-alive timeout do the ArcGIS Server and Portal Tomcat connectors use, and has anyone aligned these with the Web Adaptor?
- Has anyone seen this in combination with Dynatrace OneAgent or HTTP/2 enabled on IIS?
Any hints are appreciated. I can provide anonymized FREB traces and log excerpts.
