I have 3 layers in a Web Map that are being used in a Dashboard map element. I am trying to set the configuration so the first layer is turned on by default, while the other 2 layers (which are in a group) can be turned on by the user. When I try to do this, although the 2 layers that are turned off by default display in Map Viewer, they are not visible when I try to turn them on the Dashboard map element.
I tried turning them on by default to see if the issue persists; when doing this, one of the layers in the group displays for a second, then becomes not visible again (while the other layer is not visible at all). When I tried removing them from the group to see if that would help, it didn't solve the problem. One of these layers in the group is a large dataset, while the other isn't that large.
Has anyone else encountered this issue/are there any workarounds I'm not seeing?
