Hi all,
I am adding map image layers to AGOL using the URL from enterprise portal. I create the web maps in AGOL using the added items and then add those to storymap. What I want to do is use sidecar/duplicate slides to transition from one slide to the next as the text is scrolled. The slides will use the same web map but with different layers toggled on/off. The problem is when I duplicate the slides and try and edit the maps I dont see any option for layers, the layers dont appear in a list/dropdown to toggle. I get just the name of the web map with one tick box....not a list of the individual layers. So I dont see how I can have duplicate slides of the same map with different layers toggled on or off? Can anyone help me with this please? I even tried publishing from portal to AGOL (hosted) rather than adding with a URL but the same problem occurs!
Dave
