I am using the inbuilt QueryBuilderControl successfully with a FeatureLayer but need to use it straight from a Feature Class. Unfortunately, the control only seems to be able take a MapMember (ie Layer or Table).
Is there any way to use it with a DataConnection? The Select Features GP tool seems to be able to work that way. I did see that there is a TextExpressionBuilder control that can take a DataConnection but it is internal.
One other way I thought I might get round it is to make and use a Layer object (and not add it to a Map) but the Layer Factory forces addition to a map? Is there a sneaky way to make a Layer object without adding to a map?
Thanks in advance,
Adam
