I am working in Drone2Map and I am experiencing an issue related to coordinate reference systems.
The images are georeferenced in WGS84 (EPSG:4326), while the GCPs are in EGSA ’87 / EPSG:2100. The project coordinate system is also set to EGSA ’87 (EPSG:2100).
However, when I load the flight plan, it appears in a different location, and the GCPs are displayed in another location, far from the image block. As a result, the images, flight plan, and GCPs do not align spatially.
Could you please advise on the correct workflow for handling images in WGS84 and GCPs in EGSA ’87 in Drone2Map, and whether the flight plan should be imported or reprojected in a specific way?
Thank you in advance for your support.
Kind regards,
Sofia Karachaliou
