How do you combine custom filters (using the LayerList's `filterPredicate`) with the built-in search bar filter?
In a project using the LayerList component (using v4.33 for both core and map-components), I show the built-in search bar filter using `show-filter`, and I also provide toggleable custom filters. The setup is something like this:
<arcgis-layer-list show-filter></arcgis-layer-list>
<button id="show-visible-only" aria-pressed="false">
Show only visible layers
</button>
<script type="module">
const layerList = document.querySelector('arcgis-layer-list');
const filterButton = document.getElementById('show-visible-only');
const showVisibleOnlyPredicate = (item) => item.visible;
filterButton.addEventListener('click', (event) => {
const isPressed = filterButton.getAttribute('aria-pressed') === "true";
if (isPressed) {
layerList.filterPredicate = null; // null is the default
} else {
layerList.filterPredicate = showVisibleOnlyPredicate
</script>
The problem is that setting `layerList.filterPredicate` overrides the default search behavior. The built-in filter search bar does not work while a `filterPredicate` is defined. Am I doing something wrong, or is this just the way it works? If the latter, I would appreciate a fix, as this seems like a bug.
I could probably find a way to re-implement the built-in search bar behavior and add it to `filterPredicate` manually (I already have a system for allowing multiple custom filters simultaneously), but it seems like this should work on its own.
