I am attempting to use the Web Editor in ArcGIS Online with a task-enabled layer. I'm hoping I can use the Web Editor to speed up task creation using Copy + Paste Special but I'm running into an issue with getting a value between the source and destination layer.
The source layer has a "Small Integer" field (this layer is published from ArcGIS Pro) and the destination layer has an "Integer" field which is my only option in ArcGIS Online. I've double checked the make sure the field names match exactly (they do), but the value is not being pasted in the destination layer. With text fields it appears to work just fine. Any ideas?
