Does Portal have anything that automatically cleans up the temp folder once in a while?
I see that it is using >18 GB to hold temporary files (likely from routine WebGIS DR restores).
If there isn't an automated solution, then when is it safe to delete the files in the temp folder? Can I delete all the tmp-portal-unzip folders every time WebGIS DR finishes restoring a backup?
