Apache Sedona support as well
GeoParquet support in ArcGIS Pro - Esri Community a related idea exists as well
@DanPatterson ,
GeoParquet is supported. We want full support with web publishing, also delta tables integration.
Related idea is finalized already - https://www.esri.com/arcgis-blog/products/arcgis-pro/announcements/geoparquet-arcgis
Hi @MariusBartašius ,
Are you aware that you can share data from Apache Parquet files starting at ArcGIS Pro 3.6? The following web layers that copy all data to ArcGIS Online or ArcGIS Enterprise 12.0 and later are supported:
Thanks, I didn't know. But yet, partly answers my question, is it possible directly publish from delta tables from databricks?
I need that too.
@MariusBartašius Not currently from ArcGIS Pro. There might be a workflow to handle Databricks with ArcGIS Data Pipelines. See this help topic: https://doc.arcgis.com/en/data-pipelines/latest/connect/input-databricks.htm
We are able to connect to Azure Databricks via Simba Spark ODBC driver in ArcGIS Pro. However we have seen that Pro is able to fetch few Delta tables correctly while for some its throws error and is unable to open the tables.
However, this is just a way around as standard connector for same is not available.
Přihlaste se pro psaní příspěvků, sledování obsahu a další. Jste tu noví? Zaregistrujte se zdarma.
