In the previous Field Maps version (25.1.0), I discovered a method that allowed me to calculate attributes while still keeping the fields editable. By combining both a Calculate Expression and an Editing Expression for the same field, I was able to bypass the limitation that calculated fields become locked and cannot be edited at certain points in the workflow.
Below is an example of how this worked:
- Field: “Bestand Werte kopieren” (Copy Existing Values)
Editing Expression:
if (IsEmpty($feature.BAUWERK_REF) || $feature.BESTAND_WERTE_KOPIEREN == 1) {
return false
} else {
var relatedFeatures = FeatureSetByRelationshipName(
$feature,
"ABWASSER_MASTER_OWNER.ABW_BESTAND_BAUWERK",
['BEZEICHNUNG']
var firstFeature = First(relatedFeatures);
return (
$feature.BEZEICHNUNG != firstFeature.BEZEICHNUNG
Calculated Expression:
return 2
- Field: “Bezeichnung” (Label/Name)
if (IsEmpty($feature.BAUWERK_REF)) {
return $feature.BEZEICHNUNG
} else {
$feature,
['BEZEICHNUNG']
return firstFeature.BEZEICHNUNG;
Editing Expression:
DomainName($feature, "BESTAND_WERTE_KOPIEREN") == "Werte aus Bestand kopieren"
Why This Workflow Was Necessary (and Worked in the Old Version)
The purpose of these expressions was to temporarily trigger the recalculation of the Bezeichnung field when the user switched the value of Bestand Werte kopieren to 1. The calculated expression filled the field with the related feature’s value. Then, by returning 2, the field switched back to an editable state, allowing the user to adjust the values as needed while still having the ability to restore the copied values at any time.
Question for the New Version of Field Maps
In the new Field Maps version, this workaround no longer functions as it did before.
Is there a new or recommended approach that allows fields to be calculated while still remaining editable afterwards?
Any guidance, best practices, or alternative workflows would be greatly appreciated.
