The ability to Filter not only one field but multiple fields in Field Maps is a very helpful addition to the App. However, I think it would be nice to be able to have a setting to adjust the order of the field list in the Filter Window. To me it appears that the field order in the Filter Window is based on the order the fields were created in the dataset, which sometimes doesn't make sense or helpful to the end user.
I recommend that in the Layer Filter settings where you select Off, Selected Feature Layers and Fields, or All Features and Fields that there is few more options. First option where you can check "Honor Form Order" and it is in the order that you set up the Form. Second option is where you could drag and reorder the fields in the layer Filter settings. This would be useful in the case where if the end user filters on the same set of fields all the time, then you could drag them to the top so they are not scrolling for them, but still giving them the option to filter on the other fields if they need to.
