Hey all,
Reaching out regarding attribute rules and licensing levels as I can't seem to find a solid answer.
For context, this is in relation to attribute rules that will be created on an enterprise geodatabase and accessed by editors via feature services published on a Portal. Data editors will utilize either ArcGIS Pro to edit data, or in some instances, a solution built in Experience Builder and hosted on a Portal.
My understanding is that creation and management of attribute rules requires a Standard or Advanced license. However what isn't clear is if execution of attribute rules will occur regardless of user license level, and function for both ArcPro and Portal solutions.
Thus my question is, if a user has a Basic ArcPro License and a data editor role in the role respective Portal where the feature services were published to, when they make edits to a dataset with attribute rules applied to it, will those attribute rules be executed?
I hope the answer is yes as the attribute rules exist on the database level, but I couldn't find a source that confirms this.
Thanks in advance all,
Vince
