Hi All,
I am loading a Mobil Map Package to the Field Maps app on an Android device.
Creating the Mobile Map Package is simple and convenient in ArcGIS Pro. And the mmpk file created is easily downloaded to a device as described in ESRI's Field Maps documentation as per the link below. No problems there.
Download maps—ArcGIS Field Maps | Documentation
The map loaded to the device is easily viewable when the Field Maps app is open on the device.
However, there was one raster in the mmpk file with symbology set. Correction, the symbology was set correctly in ArcGIS Pro.
Which leads up to my question...
Is symbology from ArcGIS Pro honored in a mmpk file? And thus, honored by the Field Maps app?
Screen capture from ArcGIS Pro.
The same screen in the Field Maps app on my device. The map is loaded to my device from an mmpk file.
