When using a sidecar format with multiple map views as slides, it is not an option to enable a transition between slides. When hovering over the transition button between slides it says, "There is no transition between slides with the same media". This can make the transitions between slides as a user scrolls seem clunky and disconnected. It would be nice to see the map transition smoothly to the next location or scale instead of a harsh disappear/reappear effect.
