I have an Angular application that used to work just fine with ArcGIS Maps SDK for JavaScript 4.33. After I upgraded Angular 18 however the map would crash whenever it tries to load a feature with label.
This is the error message:
ERROR TypeError: Cannot destructure property 'vertexStart' of 'f[l]' as it is undefined.
at N.setEntityRecordRangeVisibility (4382.js:1:63183)
at s._writeLabelVisibilityToMesh (4382.js:1:37079)
at s.onMessage (4382.js:1:34990)
at or._updateTile (2686.js:1:27113)
at or.update (2686.js:1:25637)
at dr.renderChildren (2686.js:1:29136)
at dr.doRender (2406.js:1:10580)
at dr.doRender (7641.js:1:6773)
at dr.doRender (2686.js:1:34633)
at dr.processRender (2406.js:1:15240)
This is the labelingInfo of the feature layer:
Labeling Info:Label Placement: esriServerPolygonPlacementAlwaysHorizontal
Label Expression: N/A
Use Coded Values: true
Symbol:Color: [0, 0, 0, 255]
Background Color: N/A
Outline Color: N/A
Vertical Alignment: bottom
Horizontal Alignment: left
Right to Left: false
Angle: 0
XOffset: 0
YOffset: 0
Font Family: Arial
Font Style: normal
Font Weight: bold
Font Decoration: none
Min. Scale: 0.0
Max. Scale: 0.0
If I set the feature layer's labelingInfo to null then the map would load just fine, but without labels. If I try to include any label, like with labelExpression of just '1', I got the error above and the map would white out and become nonresponsive. Dev Console would continue to fire the same error.
