I have an experience builder built on Experience Builder Dev Version.
The app has 2 maps. A 2D Map is the main map and then the user can open a side bar to show a 3D Map.
The 2D map zoom extents are based off the 3D map so when the user zooms around the 3D map the 2D map follows. However when linking the 3D map zoom extents to the 2D Map it really slows down our search widget significantly so we turned that functionality off as mostly people will be looking in 2D. But now the issue is, when the user zooms into an areas on the map in 2D and wants to see it in 3D, they open up the side bar and the 3D map is at the original zoom so they have to then zoom in to where they want to go to. A bit clunky.
So what i would like is a button that makes the 3D map zoom to the extents of the 2D map. The button doesn't have many actions under button click to achieve this. Is this possible out of the box? And if not how easy would it be to create a custom widget. (I haven't created one before). Cheers,
