Hi all,
I have a connector that displays a web map in a dashboard based on a selection. When the dashboard is opened, I am generating a token via backend and passing it to the front end to call IdentityManager.registerToken(), and then initializing the web map.
I am registering a token for both the web map endpoint and the layer endpoint:
IdentityManager.registerToken({
server: "https://{portalUrl}/portal/sharing/rest",
token: ArcGISToken.Token,
// userId: "admin_user", // optional but useful
expires: ArcGISToken.Expires
server: "https://{portalUrl}/mapping/rest/services",
}); However, it still prompts a login on my dashboard that says "Please sign in to access the item on ...". Am I missing something here? I want to be able to silently authenticate and bypass the login as I've already used the username and password stored in the configuration to retrieve the token.
