Hi all,
I’ve recently redeployed the Citizen Problem Reporter solution for the third time now, and I’ve noticed that with each update, the Esri Solutions team continues to improve and streamline the experience. I really appreciate the ongoing work. It’s been great to see the evolution, especially the new integration with Field Maps Designer forms.
However, with this most recent deployment, it looks like the address field is no longer included by default. Everything appears to be handled through the Field Maps form configuration now, which is a solid improvement overall. That said, I still need an address field that is automatically populated through geocoding.
In previous deployments, I may or may not have had an Arcade expression that pulled the address into a field. Honestly, I don’t remember for sure. But regardless, with the new form setup, I simply do not know the current workaround for getting that address information into the dataset when the features are created through a field maps form.
This is important because I have a workflow set up in Microsoft Power Automate that sends notification emails when a new report is submitted. Those notifications rely on having a clear geocoded address included in the form data.
Has anyone else deployed the latest version of the solution and figured out how to get geocoded addresses (for example, from a dropped point) into a field that can be accessed in automation workflows? I’ve noticed some editing capabilities are limited since this is a managed solution, so I’m hoping someone has found a workaround that works with the latest changes.
Thanks in advance for any advice or insights.
Kindly,
cmerwin
