Hello, team, for running the WebgisDR tool. We're having trouble. When running it, we get the following message:
Error [Main] com.esri.arcgis.webgis.client.webgisdr - Before using the Webgis DR utility, you should ensure that the user account that executes each ArcGis Enterprise software component has writing permission in the specified directory where backup copies are created. ArcGIS Server cannot write in the specified directory: \ Path Directory \ temp \ Webgissite1753894351094. Check that the Board of Directors exists and that the permits are correct and try again.
There are two virtual machines. The first (DataStore and ArcGIS Server) and the second (Portal and Web Adaptor). Two folders were created on the C: drive for the Server and Data Store. The folders have read and write permissions. Two users were tested: administrator and ArcGIS service user. The ArcGIS user was elevated to administrator. The first virtual machine can see the shared folder from the second, with full access. There is no network block, and it continues to send the message. They are not in a domain environment.
Thank you so much
