We have installed ArcGIS 11.5 Portal, Server with two Web Adaptors on local machine and accessing it locally using https://[machinename]/portal, We have generated License file in which, while specifying the Organization URL We have specified[machinename].local/portal as it was required and it was not accepting [machinename]/portal, We are using ArcGIS Developer license, it has ArcGIS Professional Plus User type in it and can be used to work with ArcGIS Pro, So when We are trying to add License from portal while authenticating it gives us following error,
While Authenticating: "An unknown error has occurred. Contact your administrator to check that the license manager is running with valid licenses."
Portal Log: "WARNING Unable to obtain a license for 'username'. Failed to return valid license feature Application: ArcGIS Pro.
As per my understanding there is no license manager (might be running in background) why I am having this error and where I am doing things wrong.
Note: I am using self-singed certificate & the machine is not on any domain.
Thanks & Regards,
