I've been creating simple projects using ArcGIS Pro desktop but have been unable to create an offline map for use on Field Maps. My current workflow is as follows: Select basemap>add a kml file> share to web.
When I open Field Maps Designer in the esri enterprise environment, offline capabilities are not enabled. I have been receiving the following errors: "Layer type is not supported" and "The basemap does not contain credentials."
How can I avoid these errors and access both the basemap with KML offline in Field Maps?
