after installation to 3.5 (I´ve tried the uninstall/install procedure twice), I have a trouble with importing "arcgis" module in default Pro env - in every client - Pro/Notebook/VSCode with error:
" File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\cryptography\x509\certificate_transparency.py", line 11, in <module>
from cryptography.hazmat.bindings._rust import x509 as rust_x509
ImportError: DLL load failed while importing _rust: Access denied.
also I tried the clonned env + its update, but it´s even worse.
For "import arcpy" I am getting error:
"UnboundLocalError: cannot access local variable 'etree' where it is not associated with a value"
and for "import arcgis":
"ImportError: DLL load failed while importing etree: The procedure hasn´t been found."
Hasn´t expected that behavior, but so far it seems it´s not a general behavior, just I am just curious if you encountered the same behavior and if so whether you solved it?
Or is there a way how to "reset" the Python env?
Thank you.
