I have created a cloned copy of the default python environment.
For convenience, I put the Conda command on the PATH system variable by adding "C:\Program Files\ArcGIS\Pro\bin\Python\Scripts".
I used the Conda Forge command from a command prompt (running as Administrator, might not be necessary, but why not) to install pygplates:
conda install conda-forge::pygplates
When you try and access Package Manager ArcGIS Pro crashes. Not sure how to get out of this mess or even fix my environment - it's a bit annoying that Pro just crashes out just like this - looks like I'm looking at a re-install and all the messing about that involves.
