I am running an arcade script on my Building Footprint Layer that takes all the points (Addresses) within, and concatenates them into a string and puts the values into a field. (see below)
However, this particular script is taking hours to run?
Data is within the same sde, in a SQL database, working in ArcPro 3.3
// Retrieve the ADDRESS feature set
var address_fc = FeatureSetByName($datastore, "DBO.MasterAddress", ['Address_Full', 'AddressType'], true);
// Initialize a string to store the Address_Full values
var address_string = "";
// Loop through the addresses and check if they are within the current building polygon
for (var addr in address_fc) {
// Check if the address is within the current building polygon and has AddressType = "Address"
if (Within(addr, $feature) && addr.AddressType == "Address") {
// If this is not the first address, add a comma separator
if (address_string != "") {
address_string += ", "; // Add comma separator
// Concatenate the address to the address_string
address_string += addr.Address_Full;
// Return the collected addresses as a comma-separated string
return address_string;
