I am currently using ArcGIS Enterprise 10.6.1 and have two ArcGIS Server VMs joined to the same site for high availability and load balancing. We recently experienced an issue with one of the ArcGIS Server VMs and it had to be taken down for maintenance for an extended period of time. Luckily, the other ArcGIS Server VM is fine and everything is working as expected with the exception of Survey123. I am unable to publish new Survey123 forms.
The ArcGIS Data Store is working fine and I can view hosted feature services in Portal just fine, I just can't publish new Survey123 forms. I receive an error: "Create Service exception ' Exception: Connect to host [server name] failed: connect timed out'"
I will add that the server name that it is trying to connect to is the server that is currently down for maintenance. Obviously I expect to be able to publish Survey123 forms once the server comes back online, but I don't understand why I can't publish Survey123 forms when one server is down. Isn't one of the points of high availability that when one server goes down, the other still functions normally and picks up the slack until the other server comes back online? If that is the case, why won't it let me publish new Survey123 even when one server is down?
