How do I modify the code below to get the Buffer polygon with FLAT corners
Sub MyCreatePolygonBuffer()
Dim pMap As IMap
Dim pMxDoc As IMxDocument
Dim pFeatureClass As IFeatureClass
Dim pFeatureLayer As IFeatureLayer
Dim pFeatureCursor As IFeatureCursor
Dim pOutFeatureCursor As IFeatureCursor
Dim pfeature As IFeature
'Split lines for selected layer
Set pMxDoc = ThisDocument
If Not pMxDoc.SelectedLayer Is Nothing Then
Set pFeatureLayer = pMxDoc.SelectedLayer
Else
MsgBox "Please select a polygon layer to buffer"
Exit Sub
End If
Dim pLayerInnerPolygon As IFeatureLayer
Dim pLayerOuterPolygon As IFeatureLayer
Set pMap = pMxDoc.FocusMap
Set pLayerInnerPolygon = pMap.Layer(0)
Set pFeatureClass = pLayerInnerPolygon.featureClass
Set pFeatureCursor = pFeatureClass.Update(Nothing, False)
Set pfeature = pFeatureCursor.NextFeature
Dim pBufferConstruction As IBufferConstruction
Set pBufferConstruction = New BufferConstruction
Dim pBufferPolygon As IPolygon
Set pBufferPolygon = New polygon
'How to make use of this property ?
'Dim pBufferConstructionProperties As IBufferConstructionProperties
' pBufferConstructionProperties.EndOption = esriBufferFlat
Do Until pfeature Is Nothing
Dim pPolygon As IPolygon
Set pPolygon = pfeature.Shape
Set pBufferPolygon = pBufferConstruction.Buffer(pPolygon, 10)
Loop
AddPolygonToGraphicsLayer pBufferPolygon
End Sub
