Hello Everyone
Perhaps some one can help?
We upgraded Oracle 19c eGDB from 11.1 to 11.4 using ArcGIS Pro 3.4
Reviewing the sde_setup.log
TEST instance
[17:11:48.176] SQL Stmt: <ALTER TYPE SDE.st_geometry drop constructor function st_geometry (center_x number,center_y number,center_z number,center_m number,semiMajorAxis number,semiMinorAxis number,angle number,numpts number,srid number)Return self AS result deterministic cascade >
[17:26:48.366] SQL Stmt: <ALTER TYPE SDE.st_geometry drop constructor function st_geometry (center_x number,center_y number,center_z number,center_m number,radius number,numpts number,srid number)Return self AS result deterministic cascade >
[17:41:48.510] SQL Stmt: <ALTER TYPE SDE.st_geometry drop constructor function st_geometry (center_x number,center_y number,center_z number,center_m number,startAngle number,endAngle number,outerRadius number,innerRadius number,numpts number,srid number)Return self AS result deterministic cascade >
[17:41:48.755] SQL Stmt: <ALTER TYPE SDE.st_geometry add constructor function st_geometry (center_x number,center_y number,center_z number,center_m number,semiMajorAxis number,semiMinorAxis number,angle number,numpts number,srid integer)Return self AS result deterministic cascade >
[17:56:48.895] SQL Stmt: <ALTER TYPE SDE.st_geometry add constructor function st_geometry (center_x number,center_y number,center_z number,center_m number,radius number,numpts number,srid integer)Return self AS result deterministic cascade >
[18:11:49.038] SQL Stmt: <ALTER TYPE SDE.st_geometry add constructor function st_geometry (center_x number,center_y number,center_z number,center_m number,startAngle number,endAngle number,outerRadius number,innerRadius number,numpts number,srid integer)Return self AS result deterministic cascade >
On a copy of our TEST instance for practice:
[13:13:53.000] SQL Stmt: <ALTER TYPE SDE.st_geometry drop constructor function st_geometry (center_x number,center_y number,center_z number,center_m number,semiMajorAxis number,semiMinorAxis number,angle number,numpts number,srid number)Return self AS result deterministic cascade >
[13:13:53.214] SQL Stmt: <ALTER TYPE SDE.st_geometry drop constructor function st_geometry (center_x number,center_y number,center_z number,center_m number,radius number,numpts number,srid number)Return self AS result deterministic cascade >
[13:13:53.424] SQL Stmt: <ALTER TYPE SDE.st_geometry drop constructor function st_geometry (center_x number,center_y number,center_z number,center_m number,startAngle number,endAngle number,outerRadius number,innerRadius number,numpts number,srid number)Return self AS result deterministic cascade >
[13:13:53.633] SQL Stmt: <ALTER TYPE SDE.st_geometry add constructor function st_geometry (center_x number,center_y number,center_z number,center_m number,semiMajorAxis number,semiMinorAxis number,angle number,numpts number,srid integer)Return self AS result deterministic cascade >
[13:13:53.843] SQL Stmt: <ALTER TYPE SDE.st_geometry add constructor function st_geometry (center_x number,center_y number,center_z number,center_m number,radius number,numpts number,srid integer)Return self AS result deterministic cascade >
[13:13:54.054] SQL Stmt: <ALTER TYPE SDE.st_geometry add constructor function st_geometry (center_x number,center_y number,center_z number,center_m number,startAngle number,endAngle number,outerRadius number,innerRadius number,numpts number,srid integer)Return self AS result deterministic cascade >
So same amount of data just on separate Servers.
Any idea why on our Test Instance it was taking 15 minutes to process each statement? Compared to the copy I made.
I realise this may be hard to answer as our architecture is unknown or at least a good place to start looking. As next would be our Production instances.
Thank you.
