I was curious if anyone else is having this issue, or may know a reason I am experiencing the following issue...
It seems when I export a layer from the TOC in ArcGIS Pro into a new FGDB, the records are all accounted for in the exported layer, but there is only one point or poly for that feature class that displays on the map, and when I zoom to layer, it only zooms to the one point or poly. And no selection is on when this happens.
I notice when I import those same layers in the catalog, this doesn't seem to be an issue.
The problem is I didn't realize this was happening until I made a bunch of edits to the attribute table of the layer that is not properly displaying my points. I'm curious if anyone has a way to fix this so my points display.
Thanks.
