I'm working in ArcGIS Pro v3.3, using Model Builder to create a workflow where one branch summarizes the acres of forested landcover classes within the AOI. The landcover feature class includes a definition query which is accurately reflected in the process and the count of polygons seem to be correct on a test AOI. But to check/compare acres (that my output was correct), I clipped the landcovers using the same boundary and came up with ~1400 more acres than the Summarize Within calculation. Was this the totally wrong move? I can't imagine there would be this big of a difference! Am I completely misunderstanding the summarize tool? Thank you for your help on this - need to move past this step.
