On my PC with ArcGIS Pro 3.4 and VS 2022 I made an CoreHost C# x64 application. The assemblies ArcGIS.Core and .CoreHost are Copy Local = Yes and Specific Version = No.
My colleague runs ArcGIS Pro 3.1.3 and the app - after installing .Net 8 - can't open a file geodatabase (but I can!). Instead he gets this errormessage:
System.Runtime.InteropServices.SEHException (0x80004005): External component has thrown an exception.
at ArcGIS.Core.Internal.Interop.GetInterface(Guid& id, Object& obj)
at ArcGIS.Core.Internal.Interop.get_Geodatabase()
at ArcGIS.Core.Data.GeodatabaseUtil.OpenDatastore(String path)
at ArcGIS.Core.Data.Geodatabase.Open(Uri uri)
at ArcGIS.Core.Data.Geodatabase..ctor(FileGeodatabaseConnectionPath connectionPath)
at (my code)
Uri uri = new(fgdbPath);
Geodatabase geodatabase = null;
if (fgdbPath.EndsWith(".gdb"))
FileGeodatabaseConnectionPath connPath = new(uri);
geodatabase = new(connPath); // --- here the code breaks ---
else if (fgdbPath.EndsWith(".geodatabase"))
MobileGeodatabaseConnectionPath connPath = new(uri);
geodatabase = new(connPath); // here the code breaks I suppose (but not tried)
My question:
- does it have anything to do with the older ArcGIS Pro version? If so, what should I do, unless upgrading all ArcGIS Pro installations?
Many thanks,
Pieter
