I am setting up an ArcGIS portal 10.7.1 in Linux (Centos 7) and am running into an issue trying to configure the web adaptor. I am using a domain from godaddy and have it setup with the A names for www, portal, and @ (and they all work). I have apache SSL and Tomcat connected through a JK_mod connector. I have also installed Portal on the server and can access it through https://localhost:7443/arcgis/home.
My issue is that when i open the ArcGIS Web Adaptor 10.7.1 it gives me the following message: Unable to configure the ArcGIS Server with the Web Adaptor. Please make sure that the server machine is running and that the account specified has administrative privileges to the site.
I cannot figure out the error message and why it is not working.
The Tomcat Log shows a few error messages that might help figure out the problem:
Mar 03, 2020 2:50:42 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deployment of web application archive /var/lib/tomcat/webapps/portal.war has finished in 1,880 ms
Mar 03, 2020 2:50:46 AM com.esri.arcgis.server.wa.data.Config initialize
WARNING: Unable to load web_adaptor.properties configuration file
Mar 03, 2020 2:50:46 AM com.esri.arcgis.server.wa.servlet.WebAdaptorConfigServlet service
SEVERE: null
Mar 03, 2020 2:50:50 AM com.esri.arcgis.server.wa.servlet.WebAdaptorConfigServlet service
SEVERE: null
Thanks in advance of your help!
Andrew
