Morning,
I was wondering if there is wildcard in arcade so that I can write a simple expression that would populate a field if another field was populated with anything at all.
I have a field survey data which used to be collected on a 100x100m grid and has since changed to a 50x50m grid. What I did to calculate the number of hectares completed to display on a HUB was simply count the number of survey points.
This now won't work as there a 4 survey points per hectare surveyed.
A species list is taken on a 100x100m grid but not on the 50x50m, so I was hoping to be able to select the features that had any value in the species list field and then populate anouther field with Y then I can count this in the HUB.
I've had a look at the logic functions here https://developers.arcgis.com/arcade/function-reference/logical_functions/ but can't see anything that suggests a use of a wildcard.
