Within a chosen shapefile I have the prefix, Area, that needs to be joined to the user specified attribute, chosen as a dropdown from a column within the shapefile. which will become the suffix within a new field. For example, if the user chooses 'gridcode', then the end result should be Area1, Area2, Area3, etc for each of the rows within the Zone attribute column. I have tried to use the CalculateField_management and update cursor, but both gave me errors and since I am relatively new to python, I wanted some input to help me along. Sorry for not inserting the information below in python.
Input_Shapefile = arcpy.GetParameterAsText(0)
ID = arcpy.GetParameterAsText(1)
# Process: Add Zone
arcpy.AddField_management(Input_Shapefile, "Zone", "TEXT", "20", "2", "20", "", "NULLABLE", "NON_REQUIRED", "")
# Process: Name Zones
arcpy.CalculateField_management(Input_Shapefile, "Zone", 'Area' + str(ID), "PYTHON", "")
# Tried to use update cursor, but it created the output as AreaGRIDCODE rather than the gridcode values
# with arcpy.da.UpdateCursor(Input_Shapefile, "Zone") as cursor:
# for row in cursor:
# row.setValue("Zone", 'Area' + str(ID))
# cursor.updateRow(row)
# del cursor
# I found this option below in my searches as it appeared similar to my needs, but still no luck
# ZoneRows = arcpy.UpdateCursor(Input_Shapefile)
# Zones = ZoneRows.next()
# while Zones:
# Zones.setValue('Zone', "Area" + str(ID))
# ZoneRows.updateRow(Zones)
# del Zones, ZoneRows
