I tried performing a hit test using the ArcGIS SDK by adding an ArcGIS Raycast, Static mesh, and BP feature ID from the samples folder to my map. However, when I ran the level , the hit test doesn´t work. I also attempted the same setup at the exact location specified in the sample level, but it still didn´t work. I am using unreal engine 5.4 and ArcGIS SDK version 1.6. Additionally other levels in the sample folder such as ´´Line of sight´´ and ´´material by attribute´´ are also not working when I play their levels, although they work correctly in the Sample Viewer level.
