Our organization makes heavy use of the divide tool when working with PLSS data to do subdivision. Most of the plats we work with are in chains so we usually have our default units set to chains. However sometimes we work with private survey plats that in other units (typically US survey feet but also others). We use the divide to tool break our parcel lines proportionally by distance and the divide tool only works with the default project distance unit. It would be really nice if it allowed you to used unit overrides like the traverse tool. By not having to be changing our default unit constantly, this would be a real time and hassle saver for us.
