I’ve started to use the Print Widget in a JavaScript API 4.30 application. I have successfully published a custom printing service in my ArcGIS Server (11.1) and I can publish Pro Layouts to it and use these in the Widget, all good besides two issues I don’t seem to be able to resolve.
- The widget comes with a ‘Show print area’ button. When I configure the widget to use the out-the-box print service in the Utilities for ArcGIS Server (Utilities/PrintingTools/GPServer), it comes with a few pre-configured layout templates like A4 Landscape, and when I select these in the widget, the print area is highlighted on the map (by greying out the surrounding map). This is great, but when I change the widget to use my custom print service with my layout templates, the ‘Show print area’ does not work. I can just make out a dashed line around the very edge of my map area, so it looks like it’s trying to work, but it isn’t showing me the correct extent that comes out on the print export. Does anyone know what I’m missing? Is there some setting in the Pro layout design I need to input so the widget can work out the extent of the layout map frame? I’ve tried publishing layouts both without and with a map that has a coordinate system set in case that was it, but it doesn’t help.
- The other issue I have is with the way the widget builds the legend on my print layouts. My JavaScript API 4.x application has a MapView containing a map comprising a cached map basemap service and then a dynamic map service of layers the user can tick on and off. The legend on the layout is displaying visible layers from the dynamic map service as it should, but also all the layers that make up the background cached map. I need a way to stop the legend from building all the background cached map layers (of which there are dozens that make up the design of the pretty background map), so is there a property of the widget I can set to specify which services to include or exclude? How can I just get the legend to build the visible layers in the dynamic map service only and ignore the background map?
Thank you,
Mark.
