Hello!
I am using the ArcGIS SDK for Swift to display a 3D scene like this:
struct MySceneView: View {
@StateObject private var vm = MySceneViewModel()
var body: some View {
SceneView(scene: vm.scene)
@MainActor
final class MySceneViewModel: ObservableObject {
@Published var scene = Scene(basemapStyle: .arcGISTopographic)
init() {
let camera = Camera(
latitude: 37.752,
longitude: -122.431,
altitude: 800,
heading: 0,
pitch: 0,
roll: 0
scene.initialViewpoint = .init(
boundingGeometry: camera.location,
rotation: 0,
camera: camera
While the scene itself renders correctly, the font sizes of the labels on the base map are too small, making them difficult to read. This issue also occurs when I add a vector layer to the scene; both the labels and icons appear undersized.
I suspect that the problem is happening because the SceneView is rendering the base map at a 1x scale. On Retina displays, where the pixel density is 2x or 3x, this results in smaller visual elements. Is there a way to adjust the scale or resolution of the SceneView so that the elements become more readable on high-density displays?
Thank you!
