In ArcGIS Desktop I was able to connect to a *.mdb access database which contained the topology and data.
Based on some searches, suggest this is doable if the *.mdb is converted to *.accdb, and then use the Microsoft Access databases can be read in ArcGIS Pro using the OLE DB database connection. I have stepped thru this, and can see the table in "Catalog", but the topology does not show up.
Does ArcGIS Pro support MS Access 2007 (*.accdb)?
Thank You,
~ Jeff
