I found few posts about this without final answer.
I published a layer from database (not hosted) that has field with coded value domain.
I would like to change that domain (add, delete, update a value).
What should I do in order to see the new domain in the web layer (in update, identify etc.)
Currently I can see the domain hard coded into the rest info after the publish.
I know I can republish but it does not make sense to republish all the layers that uses this domain if I only need to add a new value.
