I'm using ArcGIS SDK 4.30 with `web-components` seasoning. Sometimes `web-components-angular`, too.
When using `arcgis-sketch` component inside of an `arcgis-expand` container, the sketches seem to "register" in the `GraphicsLayer`. They are not visible on the map. They are selectable. See this Code Pen as an example (bottom-left sketch works fine without an expand, bottom-right sketch seems buggy with expand):
https://codepen.io/vitale232/pen/WNqXMvg
I've seen the same behavior in an Angular app that depends on `@arcgis/map-components-angular` as well. Just add this markup to the sample:
https://github.com/Esri/jsapi-resources/tree/main/component-samples/map-components/samples/angular
<arcgis-expand expanded position="bottom-right">
<arcgis-sketch></arcgis-sketch>
</arcgis-expand>
Interestingly, I have an Angular component library with a public API similar to that of the `map-components` packages. The Sketch widget simply doesn't work there on 4.29+. Clicking on one of the Sketch tools never activates it.
If I use devtools to inspect the `calcite-action` elements that makeup the sketch UI, it does appear the click events are firing correctly.
Has anyone else experienced odd behaviors with Sketch and Expand in `core` 4.29+ or `web-components` 4.30+? Does anyone else using Angular 15+ and ES Modules have similar issues? Any ideas on how to further troubleshoot this? Thanks!
