I have an indoors map created and published and am wanting to use it as a kiosk map for a building. The issue I am running into is with trying to set the Home location on the kiosk mode of the Indoor Viewer App. I have a point feature class that I am using to store the kiosk locations with the idea being that I can just populate the URL with each specific "KioskID" that points to a specific point in the feature class so that each kiosk is pointed to the right "You Are Here".
I have looked at this webpage but it doesn't seem to really help. It just says to click on a feature, then click on the share button to get the URL it generates and change index to kiosk in the URL. This is fine and all but it doesn't actually tell you how to generate the URL and I can't seem to find any actual documentation on the URL parameters for this app. Additionally, this workflow that is described doesn't work for me as for some reason, when I click on the point feature for the kiosk locations in the indoor viewer, I don't get the normal Info Panel, I get a generic info panel with no share options. (See screenshots)
I have the Kiosks Point Feature Class set in the Indoors Settings, the Level_ID field is correct, and it has the same Z value as the Level that it is on.
I do not understand what I am doing wrong or why this isn't more clear on how to do the URL Parameters but I am hoping someone can help out.
