I am having an issue when using the tool "Feature Class to Geodatabase" to convert Shapefiles to Geodatabase - Feature Classes. Sometimes the elements do convert to "Geodatabase Feature Layers" as it is supposed to do, but sometimes, some elements convert to "Geodatabase Tables".
Seems like I am not the only one having this issue, here is a link of another post of someone else who had the exact same issue, but there was not a real Solution to it: Solved: Feature Classes becoming File Geodatabase Tables - Esri Community
I hope someone can help me with this, since I cannot add the Global ID field to the elements that were wrong converted to "Geodatabase Table". This is becoming frustrating, since the convertion is kind of "random", sometimes the elements do convert to "Geodatabase Feature Layer", but sometimes it will convert to "Table".
I tried using the tools "Check Geometry" and "Fix Geometry", since the "Shape*" field still is in those "Geodatabase table" elements, but they do not work at all.
