Hi all,
I'm going through the process of upgrading our test environment from 10.9.1 to 11.3 and have run into an issue with the Server component. Initial installation goes fine, as does authorization, etc., but once the install steps wrap up and the web browser opens, the final Server configuration page doesn't load (see the attached image). I've tried running the installation a few times, but I keep getting hung up at this stage. For additional context the Portal upgrade went off without a hitch. I've also made sure that the Windows service for ArcGIS Server is up and running. Anyone have any other ideas?
Thank you,
Ben
