Hi all,
I'm creating a layout in portrait orientation, where my text boxes are tilted 90 degrees, so that the text basically goes from top to bottom. I want to have the same effect with my Legend. but no matter what I do, it seems I can only make the layout frame vertical, not the symbols and text itself.
I have added a screenshot to show my situation.
I could rotate the map itself and then have a standard horizontal legend and it would work in ArcGIS Pro. However I'm going to use the layout in a Print service on our Entperprise Portal, and there it isn't going through, since I can't tilt my map in the map viewer.
So I need to create a lyout that does it for me. Any input is aprreciated 🙂
